David Zey
Chief Technology Officer
SAFIO Solutions
Customer
Industry
SaaS vendor for ecommerce and supply chain
Headquarters
Brookfield, WI
Products Used
About
Background
The Challenge
Founder Audrey Walby was keen to fix this with a solution that could easily connect their product to their customers’ tech stack. “We have clients who use Sage, SyteLine, Quickbooks, NetSuite, etc.” explains Walby. “Their forecasting system is not as robust as what they need, and they like what we have. Connecting to SyteLine is going to be different than connecting Sage, and it’s going to be different if they have Shopify, Amazon, and 3PLs. We knew to move forward we needed a really good connection point.”
With their current vendor not delivering the results they were hoping for, Walby discovered Celigo while researching for alternatives. Her choice was further validated when David Zey, SAFIO Solutions’ Chief Technology Officer, came onboard and confirmed that Celigo was a viable replacement.
“We’ve seen a double or triple-time improvement on our ability to implement the integration, as well as support when issues or changes come. Once we got our first implementation using Celigo, it immediately helped us solve some other business problems.”
The Solution
In addition, the licensing model was a critical factor, and what the ongoing cost would be as SAFIO Solutions carried out integrations for clients. “One of the things I was very mindful of was, how do we scale in a way that fits our pricing model and start with what’s the solution that fits that pricing?” Zey said. Celigo’s pricing model based on actual integration points, and not on usage or bandwidth by their client was a major draw, as they would have no limitation on flows.
Once the team learned how to use Celigo, they were able to pick up momentum and speed on implementations, running multiple projects with fewer resources at the same time. Zey was encouraged by how flexible the solution was, which made it easier to think through different approaches to solve their customer’s needs. “I realized that as the data comes into the system, if there are failures, Celigo retains the original data.” said Zey. As the data can be reprocessed, it enabled Zey to move out of an “archive” mindset of managing data via a file-folder system. “If I need to pull the data now, I can. I can still save it as part of the transfer if I want, but I don’t actually need to, and that general workflow is operationally cleaner.”
Bottomline
Having a viable integration solution has given SAFIO Solutions confidence in the sales cycle, now that it means they can win more deals and decrease the time to revenue. According to Walby, “We’ve seen a double or triple-time improvement on our ability to implement the integration, as well as support when issues or changes come.” The ability to get their product set up and running very quickly has led to happier customers, despite using fewer resources.
Additionally, SAFIO Solutions has been able to reallocate headcount previously working on integrations and manual processes into other more strategic and meaningful activities. Prior to Celigo, they had a lot more developer footprint focused on integrations, but now they have someone who understands data to be focused on integration, which provides a lot more value to their customers. And many processes that were previously manual are now fully automated.
Finally, being proactive about fixing their challenges with integration has allowed SAFIO Solutions to do a little forecasting of their own — with the improvements enabled by Celigo, Zey says that it would now be easy to figure out the cost from the path they were headed. “As we push in further and do automations around APIs and all these, the Celigo product is going to stay ahead of us in terms of our demand and need. Celigo will give us a whole lot of value in terms of being flexible and responsive to our customers.”
Mark Simon
Mark comes to Celigo having spent the last 21 years in technology. He started his career as a software developer in 1997, building e-commerce applications and custom integrations for several years. He then co-founded and led technology and operations as CTO for Evo, a successful e-commerce company that grew from $0 to $13M in revenue in three years. He then moved on to start a career in consulting with Explore Consulting, an award-winning Solution Provider and VAR. Mark has worked with clients across several industries including multiple software clients and publicly traded companies pre and post IPO. His efforts for software clients included designing and developing automated processes for sales order processing, subscription management, and provisioning among others.
